Channg "Product Version" at compile Time..
ecarbone
Post by ecarbone »
Hi;
I'm using a .bat file miabuild.exe in order to dynamically compile a project, I'm using some "compiler variables" that give me some control about how the project gets compiled and they are working fine.
What I want to do now it's to change the "Product Version" at compile time, I thought that defining a compiler variable, let's say "MY_VER" and passing the value thru my .BAT (miabuild PATH_TO_PROJECT\Project.mpr MY_VER=1.5) I'll be able to catch that on code and do something like "SET VARIABLE VERSION TO MY_VER" o perhaps "SET VARIABLE VERSION TO #MY_VER#" neither of the options worked and the version of the file keeps the value that's defined on the GUI (Project Settings -> Product Version).
Does any knows if I can change Product versin thru miabuild???
Regards,
Enrique
giaviv
Re: Channg "Product Version" at compile Time..
Post by giaviv »
Dear ecarbone,
In order to dynamically set the product version at compile time try and set the VERSION variable to #BUILDVERSION# in the MSI code.
You can refer to this thread for more information:
http://installaware.com/forum/viewtopic.php?f=2&t=4676
Best,
InstallAware Support
ecarbone
Post by ecarbone »
Thanks for the answer...I'll give a try.
Regards,
Enrique
mikKummerfeld
Post by mikKummerfeld »
Does not work.
#BUILDVERSION# and $BUILDVERSION$ is always empty (testet with Messagebox)
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Please refer to the link below;
http://www.installaware.com/forum/viewt ... f=2&t=8927
