Terminate Process: Must Have!
pointeman
Postby pointeman » Wed Dec 22, 2010 11:04 am
I'm finding it impossible to uninstall a program still running in memory. I can use "Terminate Program", but it doesn't kill the "Process". I would like to completely remove the entire app folder (Program Files\our-company\our-app) upon uninstall, but I cannot. I read a post here concerning a plugin to Terminate Processes, but It doesn't work on IA9. Help...
pointeman
Re: Terminate Process: Must Have!
Postby pointeman » Thu Dec 30, 2010 2:08 pm
I will state again that IA needs a 'Terminate Process' method to kill running processess. :)
giaviv
Postby giaviv » Thu Dec 30, 2010 2:25 pm
Dear pointeman,
Until a proper plugin is developed, have you considered calling "taskkill.exe /im PROCNAME"?
InstallAware Support
pointeman
Postby pointeman » Fri Dec 31, 2010 11:12 am
Q. Where do I get 'Taskkill.exe'?
Q. I will need to package 'Taskkill.exe' with the IA9 installer project?
giaviv
Postby giaviv » Fri Dec 31, 2010 11:34 am
Dear pointeman,
taskkill is a system process. It comes with Windows and therefore you don't need to pack it with IA.
Best,
pointeman
Postby pointeman » Fri Dec 31, 2010 2:02 pm
Here is the proper syntax to 'Force' the process to close. Just using /IM was not enough it seems. Also, don't forget the process FULL name (with '.exe') as seen in Task Manager.
Run Program $WINSYSDIR$\taskkill.exe /F /IM Updater.exe
Users browsing this forum: No registered users and 101 guests
