Can EditFile replace all?
5aclockshadow
Post by 5aclockshadow »
When using EditFile can you have it replace all occurances of the text? Right now it looks like it is only replacing the first occurance.
If this is possible how do you do it?
Thanks!
giaviv
Re: Can EditFile replace all?
Post by giaviv »
Dear 5aclockshadow,
EditFile is an external plug-in and therefore we cannot assist you with it. I tried playing around with it and it doesn't seem possible to achieve what you asked. However, I have contacted the author of the plug-in and hopefully he would be available to shed some light on your question.
Best
5aclockshadow
Thanks!
