Run Program not working
BlackNight
Post by BlackNight »
I have a line of code in my .mia file that should install a msi file on the user’s computer. after the application is installed. " Run Program $SUPPORTDIR$\InstallerTestHello.msi (WAIT)". The msi never runs. If I step through the installer with the debugger the line gets hit but does not actually run. Also if I do an Add Watch on the "$SUPPORTDIR$" Variable the value is Variable not defined if I Add Watch to "SUPPORTDIR" it has a path.
Any suggestions? Is there a better way of installing another msi file along with my app?
giaviv
Re: Run Program not working
Post by giaviv »
Dear BlackNight,
The correct way to install MSI setups is with the use of our wonderful (Un)Install MSI Setup! I actually just finished writing a tutorial on how to use it - I am attaching it here. Please let me know if you have any questions!
msi setup.docx
(1.98 MiB) Downloaded 408 times
BlackNight
Aviv,
Thank you!!! That worked great!
You guys Rock!
Paul
giaviv
Post by giaviv »
Happy to help Paul - please do not hesitate should you have any more questions!
Best
