i'm try to create a Plugin for our installer with delphi.
It all works but there is a problem with the runtime calls to the dll
function RunTimeExecute(Window: THandle; Variables, State: PInstallChar; Progress: TPlugProgressIndicator; var Return: Integer;
NewVariables: PInstallChar): Integer; stdcall; export;the dokumentation says it is the Handle to parent setup window
i really need to show a window for some special selection for our setup and without a proper parent handle these is a problem
please check
greetings from germany
Friedrich Westermann
