Preselecting a radio button
NickDay
Post by NickDay »
I have a custom dialog with a number of radio buttons. When it's displayed, none of them are selected. I'd like to force one of them to be selected when the dialog is first displayed.
In my dialog design (i.e. in the User Interface Editor) for one of my radio buttons, I have set 'Checked' to True. The other radio buttons have 'Checked' set to False. In the dialog preview in the editor, the 'Checked' button is shown selected, and the others are shown unselected. So far so good.
But when the dialog is displayed in the installer as it runs, none of the radio buttons is selected.
Is there something more I need to do?
giaviv
Re: Preselecting a radio button
Post by giaviv »
Dear NickDay,
This works perfectly for me. My best guess is that you forgot to save your dialog with the checkbox checked or that you are showing a different dialog than the one you are displaying..
bokkie
Post by bokkie »
Nick, I think this might help. I had the same problem.
http://www.installaware.com/forum/viewt ... 72&start=0
NickDay
Post by NickDay »
Thanks for your replies. Bokkie has it -- I needed to set TRUE (not just create) the variable associated with the radio button.
bokkie
Post by bokkie »
Delighted to read that it works for you as well. :)
