IIS 7 Bugs Fixed
giaviv
IIS 7 Bugs Fixed
Post by giaviv »
Dear InstallAware users,
We recently came across several issues regarding IIS 7. Those issues have been fixed. Please regenerate your license, install it, and those issues should be resolved. The fixes were only made to the setup engine, hence they wont apply to debugging inside the InstallAware IDE. They issues that have been fixed are:
1) The SSL empty bindings issue has been fixed
2) The TCP binding issue (not being able to bind to a TCP port) has been fixed
3) The Get IIS Site Index command has been fixed
4) The Get IIS Property command now returns !ERROR! instead of gibberish when passed invalid parameters
Thank you for your patience. We truly appreciate your business.
