Function Install file
Marko
Post by Marko »
Hi
I'm having trouble with installing file to users computer.
Source file is on my network (I:\Installer\test_ver.sql) and destination directory is c:\Installer (in variable $MAP$).
After Install command there is also a 'Apply Install' line.
Trouble is, that this line is not working always.
I tried also with path I:\\Installer\\test_ver.sql. Without success.
And the most strange thing is, variable SUCCESS returns COMPLETE.
Go figure.
Please, help.
Regards Marko
giaviv
Re: Function Install file
Post by giaviv »
Dear Marko,
What is this I drive? Do you have permissions to access it (and does InstallAware)? Does Move Local File work instead? Are you sure that the paths are valid? Let me know.
Marko
Post by Marko »
Hi Giaviv
Drive I is mapped drive pointing to local server. I have full rights on this drive, so does InstallAware.
I tried with network and local file without success. Or better to say, first it was successful and then stopped to work.
I'm currently using evalation version. Could be this the reason foe such a funny behavior.
Code is (with local drive):
~InstallAware Clipboard Data~
~End~
~{E4BA9FA9-140A-45E8-8CBE-E37121F8DD86}~
~End~
~{C048BBBA-1B1A-4B53-8F29-B258516E6F9F}~
~Terminate Install~
~{DC5F0EDE-EA1A-455A-AFDE-5B800BAB9111}~
~MessageBox~
~{CA2F17A7-C328-48FC-8D6C-B2970F78643D}~
~TEST~
~ERROR MESSAGE~
~0~
~1~
~If~
~{40C6B816-4E72-4AA7-9F87-37DAC69DDF3E}~
~SUCCESS~
~0~
~TRUE~
~TRUE~
~Does File/Folder Exist~
~{FC77281F-C443-41AD-AB7C-826B3C50DE0E}~
~SUCCESS~
~$MAPA_WISE$\test_ver.sql~
~TRUE~
~Apply Changes~
~{48708D66-500B-4949-83C8-EAF97BF7E555}~
~SUCCESS~
~TRUE~
~FALSE~
~Install Files~
~{201E37E9-D77E-460E-9DC6-8C31BAE6C14E}~
~C:\\TEMP\\test_ver.sql~
~FALSE|~
~$MAPA_WISE$~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~If~
~{FB22BB4C-7F0E-4FB9-88DC-438700833FC7}~
~SUCCESS~
~0~
~TRUE~
~TRUE~
~{F3EC00E6-9BF2-4BAF-BAEE-A3DE5FABD1D8}~
~SUCCESS~
~TRUE~
~Apply Changes~
~{10A69367-F287-4B22-8412-EA2F725E99BD}~
~SUCCESS~
~TRUE~
~FALSE~
~Install Files~
~{A27890CB-3DA0-494C-A171-75400FF45072}~
~C:\TEMP\TEST_VER.sql~
~FALSE|~
~$MAPA_WISE$\~
~FALSE~
~FALSE~
~FALSE~
~TRUE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~FALSE~
~Delete Files Recursive~
~{583834C9-84EC-42B2-A49E-AD99A0AA0DFB}~
~$MAPA_WISE$\*.*~
~Set Variable~
~{FC85FD34-A8FB-4C58-B226-AB53BF8178EF}~
~MAPA_WISE$MYAH$MYAH$FALSE~
~C:\PRONET\WISE~
Marko
giaviv
Post by giaviv »
Dear Marko,
Could you send your actual project to support at installaware.com? I am having some troubles pasting your script here.
Marko
Post by Marko »
Hi Aviv
I solved the problem by enabling native engine (Set Variable NATIVE_ENGINE to TRUE).
Now installing and local copying work as a charm.
Marko
giaviv
Post by giaviv »
Dear Marko,
Great!
