Hi there,
I'm applying to Logo Program W2008 R2 and one of the requirements is "TC2.11.1 - The intended behavior of each custom action must be documented". After understanding the specifications of this required documentation, I opened my IA9 generated MSI file with ORCA to see the contents of my CustomAction table in order describe each one of them. Well, the problem is I was not able to recognize any of the custom actions performed by the installer I created. Based on the IA team experience, what should I do? Is there any way to find out this connection, or should I simply disregard these internal contents and describe the custom actions performed by my MSI Script?
Thank you very much!
[b]Tiago Rocha[/b]
[i]Product Technology[/i]
www.ppi-multitask.com.br
Re: Logo Program W2008 R2
Dear Tiago,
I have been advised that these custom actions can be simply documented as "for internal InstallAware use".
Does that make sense?
