Howto install only prerequisites
dcube
Post by dcube »
I need to create an empty setup (without my APPLICATION) but with SQL SERVER 2008 R2 and own prerequisites.
It's possible ?
If yes, I able to create a small setup of my APPLICATION (without prerequisites).
Best regards
Paolo
giaviv
Re: Howto install only prerequisites
Post by giaviv »
Dear Paolo,
What I would do then is not use the pre-reqs as actual pre-reqs in IA, but install them (just like they are installed in their respective setupRUNTIMENAME scripts) in your Perform First Time Setup section.
