Can not exit debug mode on dialog error
Marko
Post by Marko »
Hi
I created a dialog with progress bar. I would like to set its max value thru program (via variable).
I created a rule where I check value of the label caption and then set the max value of progress bar.
But if I set the condition to NOT EQUAL, I got an error.
Trouble is that after that I can not exit debug mode. Even if I try to close program I got the dialog asking if I want to exit debug mode.
Confirming this dialog has no effect.
Marko
giaviv
Re: Can not exit debug mode on dialog error
Post by giaviv »
Dear Marko,
What happens is that when you get an error inside a debugged setup, InstallAware hangs as well (that is how debuggers work).
To close your debugee, go to the Task Manager the kill the debugee process.
