Is there a way to use more than 1 flash movie? Currently it seems that only 1 is allowed (add in creative a movie.swf file)
Regards,
Marc
How to add more than 1 flash
Re: How to add more than 1 flash
Dear Marc,
Unfortunately, it is only possible to show one flash movie.
I apologize for the inconvenience.
marccastaneda
Maybe this could be an enhancement in subsequent releases of installaware, this is quite a useful feature i guess.
Dear Marc,
Thank you for your input. We will definitely consider it.
mikKummerfeld
We need also more than one flash file. There should be a property at flash object to choose a flash file (like pictures)
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
Is it possible to remove the movie.swf in Temp folder at install time (right after script starts) to display language dependent flash movies in progress dialog?
Dear Alibaba,
Honestly, I never tried ... but I suppose that doesn't work, because the file must be resolved at Buildtime.
