From the help guide of install aware, you only need to specify /s and silent install would be done.
However, for my case, nothing happens. My understanding is that the default values would be supplied
(like TARGETDIR, etc.) My install application just uses the default behavior of the dialog themes (I did not do anything fancy)
I tried to set SILENT to TRUE in commandline, but it was not effective. Are there any other pre-requisite settings that need to be done (script side perhaps?)
Silent install is not working
Re: Silent install is not working
Dear marccastaneda,
Which InstallAware version are you using? Please take a look at the following thread if you are using 10.10:
http://www.installaware.com/forum/viewt ... f=2&t=6357
