Create new folder
matrix2k
Create new folder
Postby matrix2k » Wed Feb 15, 2006 9:21 am
How do I create a new empty folder during installation with InstallAware?
Gizm0
Postby Gizm0 » Wed Feb 15, 2006 9:25 am
By using the Create Folder command.
Specify the path you want, and the folder is created.
Panagiotis Kefalidis
Software Design Team Lead
matrix2k
Postby matrix2k » Wed Feb 15, 2006 9:48 am
Thanks, I'm pretty new at this..
How do I remove a folder?
Postby MichaelNesmith » Wed Feb 15, 2006 11:22 am
If you want it gone during uninstall, that's automatic.
If you will be uninstalling a folder you didn't create during the install, you can use Delete Files Recursive, or the RemoveDirectoryA function in kernel32.dll through the Call DLL Function plug-in.
matrix2k
Postby matrix2k » Thu Feb 16, 2006 3:54 am
Delete Files Recursive doesn't seem to remove the complete folder only the files inside. How do I use the Call DLL function plugin to call kernel32.dll function? Is there a sample script or a screenshot?
Postby MichaelNesmith » Thu Feb 16, 2006 6:07 am
Here is a snippet that removes $TARGETDIR$:
~InstallAware Clipboard Data~
~Call DLL Function~
~{95B5542A-DF3E-4AFF-B33E-8FCAC80C73FB}~
~RemoveDirectoryA,kernel32.dll,bool,,"pointer to string",$TARGETDIR$,$~
~mIDEFunc.dll\\mEXEFunc.dll~
matrix2k
Postby matrix2k » Fri Feb 17, 2006 7:47 am
thanks that helps
Users browsing this forum: Google Adsense [Bot] and 110 guests
