Hi folks,
I would like to add a file association to the "new" menu in Explorer's right click context menu. This is the menu you can make a new text file from, shown in the attachment.
I have had no luck working out how to do this with InstallAware. Is it possible to do this from InstallAware?
James
Explorer right click->New menu
- Capture.PNG (12.37 KiB) Viewed 3665 times
Re: Explorer right click->New menu
Dear James,
This isn't directly doable with InstallAware, however you can play with the registry to achieve this functionality - check this out:
http://www.pbdr.com/ostips/addexnew.htm
Thanks! That's the hint I needed
Good luck! You are more than welcome to post your result here so other users could use it
