My install is working perfectly on Win XP systems but is failing right after the first Installware validation progress bar screen with an "Unknown error" on a Win Millenium system
If I run the .msi, I get a Windows installer 2762 error:
Found something here but it is complete Windows Installer gibberish to me:
http://blogs.gotdotnet.com/windows_inst ... 54366.aspx
Help.
Ian
Problems on Windows Millenium system
Hi Ian
Did you try on other Win 9X operating systems, including Win98?
Did you try on a clean machine ME system?
Did you use merge modules which may require a newer MSI version than 2.0, which is the latest supported version on Win 9X?
Did you use any merge modules at all?
Does a very simple setup, for instance one which installs one file and a shortcut to it, work on the ME system?
Answers to these questions will help us track the issue down as fast as we can.
