Featureselect - Using Radiobuttons
Raubi
Post by Raubi »
Hi there,
maybe some of you know it from FireBird Installation: You can decide either SuperServer or ClassicServer, using Radiobuttons while in Feature select dialog.
Is this possible with IA too? How?
Greetings
giaviv
Re: Featureselect - Using Radiobuttons
Post by giaviv »
Dear Raubi,
I guess the best way to do this is to create your own dialog in which a user can select either SuperServer or ClassicServer and show this dialog if the relevant feature is selected. Does that answer your question?
Raubi
Post by Raubi »
yes it does. I just asked for it, maybe there is something built in which I don't know :)
giaviv
Post by giaviv »
Great :) Good luck!
