When an update is available and you click on the balloon notification, the update is not run and/or downloaded but rather the balloon message just closes.
How can you configure the update script to start the update process when the user clicks on the balloon (as the text indicates)?
Thanks, Paul
Click on balloon update notification
Re: Click on balloon update notification
Dear Paul,
Unfortunately it is not possible to change that behavior (unless your program creates a balloon and calls setup.exe /update when its clicked).
