'Problem with Shortcut' uninstalling after pinning to Start
gsRon
Post by gsRon »
When uninstalling an application that has the 'Pin to Start Menu' option selected for its shortcut, I get this message
Problem with Shortcut message
I am using AI 10.10, the machine is Win7 32bit.
If I unpin the shortcut from the StartMenu manually, before the uninstall, I don't get the message.
Is there a way to IA to remove the pinning, before the uninstall?
Ron.
giaviv
Re: 'Problem with Shortcut' uninstalling after pinning to St
Post by giaviv »
Dear Ron,
Please refer to this tutorial:
http://www.mydigitallife.info/2009/01/2 ... tart-menu/
Thanks!
