hi,
I know this question have already been answered in the past but i want to know if the situation has changed.
Can we generate a Single MSI with Installaware 10?
Create single MSI with InstallAware 10
Re: Create single MSI with InstallAware 10
Dear martien1x2s,
You can create a single Group Policy MSI, but not otherwise.
I just wanted to chime in that even though you use the Group Policy Wizard to create the single MSI package - you can use it in other deployment scenarios if you wish. Such as using System Center for example or even just running the MSI package manually - as nothing precludes you from doing that.
