Hi, does anyone still have the InstallAware 8 full setup? The reason i am looking for it is I am trying to set up a command line build on another machine. From what i have read from this forum, i would need to run the setup on that machine and then run my license file. The problem is I only have the web based setup. This setup will fail as the rest of the InstallAware8 setup files are now unavailable. I would greatly appreciate if you could make your copy available for me to download.
Thank you in advance,
Azare
