Required component, Avoid deselect,
QooScho
Post by QooScho »
In my project there are components like this:
Define Component: My Server
Define Component: My Server\Driver
Define Component: My Server\MySQL Database
Define Component: My Server\Web
I want that If "my Server" is selected the chield "My Server\MySQL Database" is always selected and cannot be deselected by the user.
I tried this:
Get Component My Server Selection State into Variable SELECTED
Select Component: My Server\MySQL Database
The problem is that the MySQL is selected but the user can deselect the item if he want.
Is it possible that in the component tree or treeview we can make a dependency to the "next" button, so that the Next button is disabled if the MySQL is not selected?
regards
Hansjoerg
giaviv
Re: Required component, Avoid deselect,
Post by giaviv »
Dear Hansjoerg,
You cannot create that constraint (I have tried before).
What you can do is check the validity of the selection AFTER the user has pressed Next, and then if the selection is invalid display a message box and go back to displaying the previous dialog.
giaviv
Post by giaviv »
Dear Hansjoerg,
QooScho
Post by QooScho »
Dear Aviv,
thank for the info.
Would be nice feature for the next version.
regards
Hansjoerg
giaviv
Post by giaviv »
I agree. This actually came up a few weeks ago and we are definitely aware of it.
anja_laenge
Post by anja_laenge »
Any updates on this?
kind regards
Anja
Set Component Choice
This command determines whether it is possible for the end-user to select or deselect a component previously defined by the Define Component command.
https://www.installaware.com/mh52/deskt ... rhsyns=%20
anja_laenge
FrancescoT wrote:Set Component Choice
Thank you! I missed that.
kind regards
Anja
