Uninstall components individual
QooScho
Post by QooScho »
For installing I show the component tree with the options. Users can selecte the items.
If I click to Uninstall, all components and files which are installed will be uninstalled.
Is it possible to make a selection for uninstalling single options?
For example:
Define Component: My Server
Define Component: MyServer\MySQL Database
For uninstalling I want that the user can choose if MySQL will be also uninstalled or not.
best regards
Hansjoerg
giaviv
Re: Uninstall components individual
Post by giaviv »
Dear Hansjoerg,
All you need to do is go to the Modify Features maintenance page (instead of selecting uninstall).
This will allow you to deselect features which will be later uninstalled. This is standard installer flow.
Just make sure you wrap MySQL in a feature (which I'm sure you did given that you want to uninstall it).
