Predefined variable for User App data?
QooScho
Postby QooScho » Mon May 23, 2011 8:24 am
is there a pre defined variable for
c:\users\[Name]\AppData\Local ?
or
c:\users\[Name]\AppData\Roaming?
I need to install some files to this directory
regards
Hansjoerg
giaviv
Re: Predefined variable for User App data?
Postby giaviv » Mon May 23, 2011 9:11 am
Dear Hansjoerg,
You can use the Get Folder Location for the directory System->Application Data.
If you uncheck the Get for All Users box, you will get the current user's application data, which on Windows Vista / 7 is usually c:\Users\{user}\AppData\Roaming.
Nhamzei
Postby Nhamzei » Fri Sep 13, 2019 11:35 am
Can you describe how to do this?
Where do I find System-->ApplicationData in InstallAware and where is the Get for all users checkbox?
I am using InstallAware X9
Postby FrancescoT » Mon Jan 27, 2020 12:23 pm
Users browsing this forum: No registered users and 69 guests
