Install IIS as pre-requisite
kishan1
Post by kishan1 »
I need to check & Install IIS server as setup prerequisite if not preset on client machine. I'm using Installaware 10.10. Does installaware provide such option?
Thanks in advance.
-Kishan
giaviv
Re: Install IIS as pre-requisite
Post by giaviv »
Hey Kishan,
You can read the registry using the Read Registry command in InstallAware. The IIS version key is located at:
HKLM\Software\Microsoft\InetStp\MajorVersion
HKLM\Software\Microsoft\InetStp\MinorVersion
As for installing IIS, that's a whole different issue - IIS is a component of Windows and can't be installed manually because it doesn't come as a standalone application, but rather it requires the Windows DVD to install.
