I have just installed ia11 studio version with everything.
I create a new .net template which I see adds the x86 runtimes for the .net4 framework for both client and the full framework and also adds the windows installer 3.1
If I try to build this without adding anything I get an error message
Script Load Error
This script uses a plug-in that is not available on your system:
Please install this plug-in before opening this script. Closing project now.
To install plug-ins:
1. Open the Control Panel "Add-Remove Programs" applet,
2. Choose the "Change" option for InstallAware,
3. Select "Add or Remove Features" and install missing plug-ins.
OK
Then a 2nd message
untitled - InstallAware Studio
Unable to find saved script context for
OK
I have checked the features installed and everything is installed.
What is going on?
Unable to build an empty .net project type IA11
Re: Unable to build an empty .net project type IA11
It seems like InstallAware didn't properly install on your machine - please completely remove it and install it again.
Haha yes that sorted it.
Slight concern when you have to reinstall a piece of packaging software due to failing to install correctly.......heres hoping my software doesnt have the same problem.
Hahaha ironic, I agree, but this is likely stemmed from a current state of your machine rather than a faulty installer..
