Features in version 5.2
Ton_B
Postby Ton_B » Wed Mar 01, 2006 9:19 am
I see there is a new version available for download (5.2) but I do not see the implemented features.
I am wondering if the problem for unattended setups is solved.
So if you start the created msi with commandline "\\quiet" the installaware executable will indead start in the silend mode "\\s" ???
This is still a very important issue for our setup !!
see topic:http://www.installaware.com/forum/viewtopic.php?t=501
I'm really looking for a solution.
I've already tried to create a custom action using orca, but the main problem is how to detect if the commandline "\\quiet" is set, and if so, how to change the record "CMDLINE" to "\\s"
Postby MichaelNesmith » Wed Mar 01, 2006 8:11 pm
Dear Ton
Please continue using the switch CMDLINE="/s" for the meantime.
5.2 contains various fixes to real bugs (features not working as they were documented) and adds marquee progress bars. It is a minor update.
Users browsing this forum: No registered users and 107 guests
