FAQ - read before posting!
Locked
giaviv
Post by giaviv »
Hey guys,
Here are some tutorials / threads / white-papers that might come in handy!
Branding Removal in InstallAware 11
Installing 3rd Party Setups within InstallAware Using the (Un)Install MSI Setup plugin
Loading Pictures Dynamically onto Dialogs at Runtime
New Web Media Block Pre-defined Variables
Clarifications About UAC Elevation
Displaying a Progress Bar During Silent Installs
Example on How to Set IIS Binding on IIS 6 and 7(thread)
Example on How to Get IIS Binding on IIS 5, 6 and 7(thread)
How to use InstallAware Translation Tool
translation tool.pdf
(17.2 KiB) Downloaded 7063 times
Basic Dialog Action sample
The sample demonstrates how to execute script code conditionally as result of a dialog button selection.
Basic dialog action.rar
(51.69 KiB) Downloaded 7058 times
Check Disk Space sample
The sample demonstrates how to format disk space value in; Kb, MB and GB.
CheckDiskSpace.rar
(3.68 KiB) Downloaded 6086 times
Dialog control state
The sample demonstrates how to set the state of a dialog control at runtime.
DlgControlState.rar
(3.26 KiB) Downloaded 6061 times
Enumerate MS SQL Instances sample
The sample demonstrates how to enumerate via IA script, installed MS SQL instances on target machine.
EnumerateSqlInstances.rar
(5.11 KiB) Downloaded 6855 times
Features sample
The sample demonstrates how to handle features with the installer.
Features.rar
(795.51 KiB) Downloaded 6647 times
Features sample (2)
The sample demonstrates how to keep track of features selection and TARGETDIR, with different version of a setup.
Features (2).rar
(848.88 KiB) Downloaded 6344 times
Multiple target directories sample
The sample demonstrates how to handle the selection of multiple directories from the destination dialog.
Multiple target directories.rar
(1.75 MiB) Downloaded 6182 times
ODBC sample
This sample demonstrates how to create a 32/64 bit ODBC data source.
Pleease note that a 64-bit version of the Microsoft Windows operating system includes the following versions of the Microsoft Open Database Connectivity (ODBC) Data Source Administrator tool (Odbcad32.exe):
The 32-bit version of the Odbcad32.exe file is located in the %systemdrive%\Windows\SysWoW64 folder.
The 64-bit version of the Odbcad32.exe file is located in the %systemdrive%\Windows\System32 folder.
To run the sample, please verify the presence of the following requirements with the target system;
- "SQL Server Native Client 10.0"
- "SQLEXPRESS" MS SQL instance
ODBCTest.rar
(2.77 MiB) Downloaded 6163 times
Permissions sample
This small sample demonstrates how to grant permissions to folders and Registry key.
Permissions.rar
(3.84 KiB) Downloaded 6092 times
Shortcuts sample
The sample demonstrates how to set the "Run as Administrator" flag with the installed Test Application (TestApp) shortcuts (Desktop and Application Start Menu).
RunAsAdmin_shortcut.rar
(4.02 MiB) Downloaded 6590 times
WebUpdate sample (customized)
The sample demonstrates how to run the "update scheduler" mode at the end of the installation process.
The default "Scheduled Web Updates" mode is also supported, in case the "update scheduler" settings are not confirmed with the above implementation.
WebUpdate (customized).rar
(1.27 MiB) Downloaded 6729 times
Locked
