I just upgraded from 10 to 11. Now when I try to build my project I get an error including framework 4. I get:
No files matching wildcart pattern
c:\progra~1\Instal~1\INDF0C~1\runtimes\net40bin_x86\*.*
I've tried unselecting and selecting the framework, but still no luck. What do I need to fix to fix this?
build failure after upgrade
Re: build failure after upgrade
Hi SteveRing,
The .NET 4 runtimes have changed in InstallAware 11. They are now in different folders and have different include scripts.
Please remove the old ones from your script by unchecking the runtimes. Then, delete the runtime script files from your project folder (checknet40 and setupnet40). Now add the new updated runtimes by checking them in the IDE.
The new runtimes are smaller and display accurate install progress.
