Load user selected file during install
andyc
Post by andyc »
Is it possible to have a dialog that asks a user to upload a file from their file system during install?
The use case for this is so we can ask the user to add a license file that we have provided via email or similar. We can then read the contents of the file to install the license as appropriate.
I know I could pretty easily ask for the path to the license file, but this seems a bit clunky from a UI perspective.
Thanks!
giaviv
Re: Load user selected file during install
Post by giaviv »
Hey,
You can simply use the destination dialog as a base for your new dialog - it does more or less what you want, except the use will have to select a file rather than a folder..
