Hi
Im having some problems creating virtual directories in IIS. Ive used the Project wizard to create the installer.
this is the command im using:
Create Virtual Folder "\\Skin" in IIS Site #1, pointing to physical location $TARGETDIR$
I've tried putting it in before and after Apply Install
Am I missing something?
Im using InstallAware 2005 (sp1.passion_update2_rtm.050927)
Problems with Create virtual folder on windows 2003 standard
Hi
I'd try without the leading slash. You do need to put it in after Apply Install. Also make sure the referenced IIS site already exists!
Users browsing this forum: No registered users and 108 guests
