Good day,
I was wondering if there is any way to customise or completely replace the dialog shown initially on the start of the installation. Or should I call it the Dialog within the Bootstrapper?
I have attached a screen dump of the dialog that I am talking about, and named it "Bootstrapper.jpg".
Thank you
Customising Initial Boot Dialog
- Bootstrapper.jpg (9.7 KiB) Viewed 4824 times
Re: Customising Initial Boot Dialog
Good day,
I was using a debug script when I captured the screen which I want to customise... the initial attachment I would still like to customise the text, however I do know that I can use the "Creatives" segment to customise some of the previously attached screen.
I have attached the actual Bootloader Screen that I would like to customise, and would ask if it is possible.
As can be seen, I have managed to update the icon, using the "Creatives" segment, but I want to be able to change the text too.
In the previous post, I know that if I add a 32x32 png I can change the "Icon" there too... but within that screen I would like to change the text too.
- Bootstrapper.jpg (12.32 KiB) Viewed 4823 times
These strings (they are called installer shared strings) are editable via the mTranslator tool. It is located in the InstallAware directory\trans.
Thank you sir.
You are a scholar and a gentleman.
I will give this a go... if I have issues, I hope you will be willing to assist
No problem. Let me know if you have any other questions!
