Build Performance
erezb
Build Performance
Post by erezb »
HI!
The build performance is very slow. we are using build compress. the installation type is .Net Project.
During the process we saw it stuck even when copying a simple light file.
We tried that when network destination path and also as local but it didn't help.
What can we check or do in order to improve this bad performance?
Thanks!
Erez
giaviv
Re: Build Performance
Post by giaviv »
Hi Erez,
To speed up the build, try going to Project Setting an decreasing the compression under Build -> Compression.
