Read Registry Key no complete way
Merops
Post by Merops »
I want to know if a key exists, but I do not know her way around as it depends on user input (database name).
For example :
HKCU\Software\MySoft\DatabaseXYZ
HKCU\Software\MySoft\BaseABC
I try "Check Registry Key HKCU\Software\MySoft\*" but result is "NOKEY".
Bests regards,
Franck :wink:
giaviv
Re: Read Registry Key no complete way
Post by giaviv »
Were you actually using the string "HKCU\Software\MySoft\*" or did you replace * with the correct key name?
Merops
Post by Merops »
I do not know the full name of the key because it depends on the user input.
I try :
Check Registry Key HKCU\Software\MySoft\%
But, the result is "NOKEY".
Thank you for your help,
giaviv
Post by giaviv »
I'm still not sure im getting it - you can't use * as the key name, you have to specify a specific key..
