The setup must update files and services ..
QooScho
Post by QooScho »
While uninstalling my program I always get the message
"The setup must update files and services that cannot be updated while system running"
I do not undestand why this message appear
The uninstall process seems to be ok. All files and the window service are removed after uninstall
any idea?
regards
Hansjoerg
giaviv
Re: The setup must update files and services ..
Post by giaviv »
Dear Hansjoerg,
What exactly does your program do? How are you running the install and it what stage to you get this message?
QooScho
Post by QooScho »
Hello Aviv,
I think the command s from blolapiertall are all SPAM. This is very confusing
I get this message with IA 10 at the end of the uninstalling process. Uninstall deletes all files and and one window service
I the message appear and I click OK the wizards end uninstalling.
Then all is fine. All files are deleted and also the service is removed
But why this message?
regards
Hansjoerg
giaviv
Post by giaviv »
Hansjoerg,
Is that service running during uninstall?
