Element Path/Edit XML file
tpritchett
Post by tpritchett »
Element Path
Type the path to the element, including the root element. Start with the root element, and separate each following child element using the \ character
Is there any plans to support Xpath type notations in the 'Element Path' for edit XML file
for instance like:
root\parent\child[@myattr="somevalue"]
bokkie
Re: Element Path/Edit XML file
Post by bokkie »
That would be a very nice addition! I'm a big fan of Xpath. I suppose that as XML made it's appearance in version 11 for the first time small steps are perhaps better than none. :D
giaviv
Post by giaviv »
Thank you for your input guys.
We will let you know if and when we plan to introduce this feature.
PaavoN
Post by PaavoN »
Hi
Any updates on this one ? This would be really useful feature.
Dear PaavoN,
unfortunately there isn't any update about this specific matter.
However the most recent version of IA include the "Evaluate XPath Query" command, which was not available at the time this thread was started.
