Run the Application (at the end of installation)
gianluca.debonis
Postby gianluca.debonis » Sun Feb 13, 2005 6:52 am
I'm evaluation the demo version of IA professional 3.0.
I'm ready to buy, but I'm experiencing a strange effect of RUN APPLICATION. Using the generated installation package, if I choose to install in the default directory everything goes well. But if I choose to install in another disk... the application will not start (anyway the desktop & menu links will work), and no error will be displayed.
Is it a known bug? Am I doing something wrong? Why it is not possibile to specify the launching directory?
I'm using the command:
Run Program $TARGETDIR$\\<executable_name>.exe
Thank you in advance
GLDB
sinan
Postby sinan » Sun Feb 13, 2005 9:16 am
This is a known issue which occurs when the wizard loop command is used to display the destination directory dialog. :oops:
A fix for the issue is available for our licensed users, or in the meantime you can use the Project Wizard to generate a new install with the I wish to allow users to select the application features to install option (specified in the Dialogs page) to get code you can copy-paste into your existing setup, so it doesn't exhibit this erroneous behavior.
I apologize for the inconvenience.
sinan
Postby sinan » Sun Feb 13, 2005 9:21 am
Please let me know if this answers your question :)
gianluca.debonis
Postby gianluca.debonis » Sun Feb 13, 2005 10:15 am
Ok, thank you for the info. Now I'm going to buy IA Professional; where could I get the fix?
sinan
Postby sinan » Sun Feb 13, 2005 10:57 am
I have privately sent you the download information.
Thank you for choosing InstallAware :D
Users browsing this forum: No registered users and 25 guests
