Hi!
I need to register a VB6 ActiveX EXE.
It seems that this can not be done with the commandline parameter /RegSvr.
The command 'Register Library' also returned FALSE.
What else can I do?
Mike
How to register a VB6 ActiveX EXE?
My point in my previous post was that if regsvr32 won't register it then IA won't register it.
I would check with the entity that provided a VB6 active X Exe and find out how they expect it to be registered then implement that in your script.
If this is an in hous program I personally would recompile it as an acitve x dll or ocx.
an ActiveX-EXE can never be registered with regsvr32.exe - this type of ActiveX component is self registered by the first execution of itself. So simply run the ActiveX-EXE to register it
cu
Markus
cu
Markus
Markus Diettrich
If it can't be done with InstallAWARE then you are not using Windows
Hi!
Thank you, but the problem is, I don´t want to start the program after installation. (The ActiveX EXE is only a part of the installed program).
I found out that it works if start it manually from the commandline with the switch '/regserver', so I tried to add the command 'Run program' with the command line parameter '/regserver' to the install script but that still doesnt seem to work
Any further help would be greatly appreciated
Mike
Mike
Users browsing this forum: No registered users and 27 guests
