HI,
Can somebody tell me if it is possible without compilier variables to auto detect if a file is present for inclusion into a build of the single exe. Instead of a compilier variable I would like to control the inclusion of a set of install files and or build type of installation, by looking to see if the build files are present?
Is this possible and if yes how?
Steve
Control build input files
Re: Control build input files
Hi Steve,
Unfortunately, there is no definitive way to do this in IA.
I would recommend using some sort of script file to manage the files.
