Hello all,
I'm trying to debug my setup in the IDE, but I only have the 'Run without Debugging' command available under the Run menu, all the other commands are missing.
I'm using InstallAware Developer 5.2 and I have the 'Debug Build' option checked under the project options. I also run the builds using the Uncompressed Directory Layout Type and I have compression set to none.
How do I enable integrated debugging???
Thanks for a hint...
Thomas
Debugging in IDE
Hi Thomas!
Debugging is available only with Studio and higher. You could try InstallAware Studio.
Hi Thomas!
Please contact me privately for a discount coupon
Users browsing this forum: No registered users and 133 guests
