Compare 2 Textbox
vasanthmnr
Compare 2 Textbox
Post by vasanthmnr »
How to comnpare two textbox in Installaware?
Suppose there is password and confirmpassword textbox, before move to next dialog box, i need to validate the two textbox values are equal or not.
giaviv
Re: Compare 2 Textbox
Post by giaviv »
You can have both textbox write to variables (double click on the textbox in the form editor and select writes value to variable).
Then, use an If..Else..End block in your MSIcode to compare the two variables.
