I am having an issue with Workstation Company and Workstation Name pulling a default value of "Microsoft" within the installer. I am utilizing the object behavior tab on define interactive characteristics. I found that someone reported the same thing back in January, but there was no answer on that thread. Any help would be greatly appreciated.
Issue with Workstation Company and Workstation Name
Re: Issue with Workstation Company and Workstation Name
Where are you looking that you are seeing these values?
Hi Aviv,
I am seeing the values being populated with 'microsoft' in the completed installer. The installer runs fine and installs fine, but during personalization, the fields Name and Company are 'Microsoft'. Interesting thing though-- if I run the installer (I'm on a 32 bit Win7 Enterprise installation), I'm getting the correct values pulled. I'm trying to find out if the user who reported the problem is running a 64-bit version of Win7. It's quite strange.
Could you please attach a screenshot?
I have attached the screenshot showing the 'Microsoft' entries. This is, indeed, occuring on a 64-bit Windows 7 install only. I'm running 32 bit and it pulls my user name properly.
Thanks!
Thanks!
- 64bit Screenshot.jpg (72.55 KiB) Viewed 4874 times
Please send your project to support at installaware.com
Thanks!
Thanks!
