Apply Install problem
FJGG
Post by FJGG »
I noticed a problem when i was customizing the installer scripts....when i changed the 'Apply Install (get results into variable SUCCESS)' statement to 'Apply Install' and build then run the installer, registry (write/read) and Install Files or just create a folder on the target machine, it won't work the next time I revert the command line to 'Apply Install (get results into variable SUCCESS)'.
Am I missing something?
I built a setup, took out SUCCESS from Apply Install, ran it - everything worked fine.
Then I added SUCCESS back into Apply Install, rebuilt it, ran it - everything worked fine again.
I don't see what you are referring to when you say it wouldn't work the next time.
FJGG
I missed out the needsupgrade checking!
Post by FJGG »
Thanks for replying ... it was my mistake ... i commented the codes that checks if the installer needs an upgrade ... therefore it detects that a previous installation is already present ... :D
