Empty folder causes Build error
ncgjka
Post by ncgjka »
I have a treestructure defined in my TARGETDIR
-FolderA
----FolderB
----FolderC
When I build my project I get an error saying
"Error during build: No files matching pattern ..\\..\\FolderA\\*.*"
The FolderA happens to be empty, only has the subfolders which contain files. If i add a "dummy" file Text.txt in FolderA the Build works!
Is there any other way around this problem, I do not want to have the dummy file in the folder.
Did you actually check the "Include subfolders if wildcards used" box on the Install Files dialog?
ncgjka
Post by ncgjka »
Yes, I checked that option. But the problem is that the FolderA does not contain any files. If I add the dummy "Text.txt" file in the source FolderA it works. It seems the compiler does not like empty folders...?
I tried this as you described - created two folders inside an empty folder - and placed a file inside one of the subfolders. It worked just fine, so I don't know what's wrong at your end, sorry.
ncgjka
Post by ncgjka »
Ok. I'll see if I can figure iy out.. Must be some wierd mismatch somewhere. Thanks anyway!
