Delay Before Loading movie.swf
jamesish
Postby jamesish » Mon Aug 01, 2011 8:14 am
I added a movie controller to my installer's progress screen using the browser->flashFrame option.
When I am clicking through the installer, there's a noticeable delay of several seconds after I click "next" on the screen before the progress dialog box. Presumably, the flash player is unpacking itself and loading the movie. I was wondering, though, if there's any way to remove that delay.
giaviv
Re: Delay Before Loading movie.swf
Postby giaviv » Mon Aug 01, 2011 11:28 am
Is your movie heavy / full of things that require a lot of resources / is your target machine relatively weak?
I am experiencing no noticeable delay, but any of the above might be causing your issue.
jamesish
Postby jamesish » Tue Aug 02, 2011 9:45 am
Hi Aviv,
the movie is a 3 megabyte swf file that only displays a movie; it has no interactive elements.
I've noticed that if I run the installer once, there's a noticeable delay the first time that the movie will be displayed. I can cancel the installer, then start the installer again and the second and subsequent times I run the installer there's no delay.
The computer I'm running this on is running with 12 gigs of RAM, 7200RPM hard drives and an i7-940 processor.
Do you have a small movie I could download and embed in my installer so I can verify that it's the movie that's the problem? It could still be, if the movie is being scaled significantly or something.
Thanks!
giaviv
Postby giaviv » Tue Aug 02, 2011 10:17 am
Yes that makes sense.
Unfortunately I don't have such a movie, but I am sure a simple Googe search would yield a lot of results..
Anderson
Re: Interaction with .swf
Postby Anderson » Fri Jan 16, 2015 3:24 am
i added a flush movie.swf to my project, how can i get the click events on my .swf so that they can change variables on the dialogue
Postby FrancescoT » Fri Jan 16, 2015 2:13 pm
Unfortunately, it's not possible to catch the click event in this case.
Users browsing this forum: No registered users and 78 guests
