SSL over HTTP Web Downloads
tiger9091
Post by tiger9091 »
Can you verify that Installaware requires that the web media blocks be available via HTTP, and not HTTPS? I was unable to run the installation when the web media blocks were on an HTTPS site, but it ran without issue when I moved the files to an area available through HTTP.
Post by CandiceJones »
I believe HTTPS should also work...as long as the URL is specified correctly, and the server is serving the data over the secure connection correctly. In fact you could even use FTP, network shares, and more...all as your download URLs.
tiger9091
Post by tiger9091 »
Thanks for the information. First of all, I did not realize that I posted to the presales forum. If I need to move to tech support, let me know. You mentioned if the server is serving the data over the secure connection correctly. I believe we have that set up correctly, but the web media downloads fail if I use a (correct) HTTPS reference instead of an HTTP. Is there a specific setting for ignoring/accepting client certificates I should check on the website?
Hi!
As long as your server is able to serve the file, it should all work. You can try entering the URL into Internet Explorer and see if that works - always a good way to test. Also double-check your download URL. Finally, make sure you don't have any firewalls and/or other security software blocking or interfering with downloads.
