Trying to convert an InstallShield Pro 11.5 project to InstallAware 11.
As soon as I select the InstallShield project, I get this error:
Access violation at address 56Fxxx in module 'SalvationShield.dll'.
See attached picture.
I'm running the latest InstallAware version that I downloaded from your web site today.
My computer is running Windows 2008 Server R2.
Conversion from InstallShield 11.5 fails with Access Violati
- InstallAware-Error-01.png (75.83 KiB) Viewed 20952 times
Re: Conversion from InstallShield 11.5 fails with Access Vio
Are you able to send your InstallShield project to support at installaware.com?
I can send you the project. Give me an email address to send it to.
its support at installaware.com
Just sent the project.
The InstallAware InstallShield converter only works on InstallShield projects saved in XML format.
Please save your project as XML and try the conversion again.
Thank you. That did it.
