registry put the entry under the wrong path
nofarr
Postby nofarr » Mon Aug 08, 2011 8:03 am
i'm using installaware 11
i did export from registry in one machine (64bit) and did import in the installaware to the registry
i see the entry in the installaware under the path
HKEY_LOCAL_MACHINE->SOFTWARE->ODBC->ECSDB
but after installing the package on other machine the entry appears under WOW6432Node
i couldn't understand what cause this
i config the setup to be 64 bit
do i need to config something else?
giaviv
Re: registry put the entry under the wrong path
Postby giaviv » Mon Aug 08, 2011 10:11 am
In order for your registry value to not be written to that node on a 64 bit machine, you would have to call Set 64 Bit Mode command and select x64.
When you say "i config the setup to be 64 bit", what exactly did you do?
nofarr
Postby nofarr » Tue Aug 09, 2011 1:14 am
hi,
i mean that in application Requirements window i chose the option :
64 bit operating system
do i need to do something else?
nofarr
Postby nofarr » Tue Aug 09, 2011 4:41 am
hi,
i solved the problem :)
i added after the write to registry option the set x64 option
i thought it's enough to set it on the begining but it's not.
thanks any way :)
giaviv
Postby giaviv » Tue Aug 09, 2011 11:55 am
Sure!
Users browsing this forum: No registered users and 51 guests
