Extract file Version info at compile time
IanM
Postby IanM » Tue Mar 14, 2006 10:20 am
I would like to be able to extract the version number from my key application file at compile time and use this to align the install program Version number that appears on dialogs etc.
Any suggestions?
Postby MichaelNesmith » Tue Mar 14, 2006 5:18 pm
You can try the automation interface to programmatically emit a setup project and build it...
IanM
Postby IanM » Wed Mar 15, 2006 12:45 pm
MichaelNesmith wrote:You can try the automation interface to programmatically emit a setup project and build it...
Thanks Michael,
I was just being lazy and it is probably not worth the time it would take for me to code this up vs. manually changing the version numbers in each project.
However looking at the Automation DLL miaInitiliaseProject function made me wonder if miaBuild could be enhanced in the future by allowing any/all of the project settings such as Version number , manufacturer etc to be piped via an ini or XML file.
Ian
Postby MichaelNesmith » Wed Mar 15, 2006 1:22 pm
Sure, I'll log this in as a feature request for you! Thanks for the suggestion.
tofutim
Re: Extract file Version info at compile time
Postby tofutim » Thu Jan 23, 2014 3:06 pm
Any chance this was ever addressed?
Postby FrancescoT » Fri Jan 24, 2014 10:26 am
If you are reffering to the possibility to use an ini or XML file with IA Automation ... unfortunately, this is not possible.
Users browsing this forum: No registered users and 115 guests
