manipulating forms and components
bendrouet
Postby bendrouet » Tue Mar 14, 2006 10:25 am
I have a question about the forms and the components it contains.
If I create a custom form via the form editor and add to it a list box, it that possible for me to fill the list at runtime ?
for example
Form1.MylistBox.Items.Add (.....)
Is there a way to manipulate the forms as object like this and access the component it contains ?
thank you.
jimo
Postby jimo » Tue Mar 14, 2006 10:32 am
There is no way to manipulate forms and the controls it contains at runtime ala OOP.
You can however populate a List Box or Combo Box at runtime with something like:
Read from Text File $SUPPORTDIR$\\osqloutput.txt into Variable LINE1 (get EOF into ISEOF)
Read from Text File $SUPPORTDIR$\\osqloutput.txt into Variable LINE2 (get EOF into ISEOF)
label: Read osql Output
Read from Text File $SUPPORTDIR$\\osqloutput.txt into Variable NEXTLINE (get EOF into ISEOF)
if Variable ISEOF not Equals TRUE
    if Variable MYCOUNTER Equals 1
      Set Variable COMBOITEMS to $NEXTLINE$
      Set Variable MYCOUNTER to 2
    else
      Set Variable COMBOITEMS to $COMBOITEMS$$NEWLINE$$NEXTLINE$
    GoTo Label: Read osql Output
label: Read Finished
Users browsing this forum: No registered users and 77 guests
